TX Rainbow Bridge
This explains what Continuous Truss means. I had to look it up :)
A continuous truss bridge is a truss bridge which extends without hinges or joints across three or more supports. A continuous truss bridge may use less material than a series of simple trusses because a continuous truss distributes live loads across all the spans; in a series of simple trusses, each truss must be capable of supporting the entire load.
Although some continuous truss bridges resemble cantilever bridges and may be constructed using cantilever techniques, there are important differences between the two forms. Cantilever bridges need not connect rigidly mid-span, as the cantilever arms are self-supporting. Although some cantilever bridges appear continuous due to decorative trusswork at the joints, these bridges will remain standing if the connections between the cantilevers are broken, or if the suspended span (if any) is removed. Conversely, continuous truss bridges rely on rigid truss connections throughout the structure for stability. Severing a continuous truss mid-span endangers the structure. However, continuous truss bridges do not experience the tipping forces that a cantilever bridge must resist, because the main span of a continuous truss bridge is supported at both ends.
It is possible to convert a series of simple truss spans into a continuous truss. For example, the northern approach to the Golden Gate Bridge was originally constructed as a series of five simple truss spans. In 2001, a seismic retrofit project connected the five spans into a single continuous truss bridge.
Here's rankings for Continuous Truss bridges in the world.
https://en.wikipedia.org/wiki/List_of_longest_continuous_truss_bridge_spans
https://www.usatoday.com/story/trav...8/10-longest-bridges-to-drive-across/2118739/
Lake Pontchartrain Causeway - 126,122 feet
According to the Guinness Book of World Records, the Lake Pontchartrain Causeway is the longest continuous bridge passing over water, the waters of New Orleans's Lake Pontchartrain to be exact. The bridge is so long that for 8 of its 24 miles, you can't see land in any direction.
Harry
Have crossed that lon————-g thumpety thump 10 bridge many times but not on a bike. Never a good place for a breakdown for sure. Driving westbound with mom sleeping in lower starboard side bunk over rear wheels, Outside dual let go. Luckily close to end and got off that bridge. She was mad at me and brother for going across it right before dark... she was really happy when that happened
Yeah, it’s long! And swampy!
