Hi Kurt,
I did a thorough cleaning such that it looks like Alan's picture. Good idea on the resistance checks, I will do that (fourth time taking out the field coil plate!).
I also found on the 6V VW forum a check for the generator output. You basically disconnect the generator from the regulator and run the generator separately. Theoretically without the regulator it should read about 17V. It turns out that a bad regulator can keep the voltage too low by restricting the current. The VW forum showed a drawing of their Bosch regulator and it looks a lot like the R27's. They do mention that the electronic regulators may solve that problem as they can correct a wider range of voltage/current issues.
Now that the seat is off I will lift the tank off to clean the regulator contacts first and check that wiring for continuity. Sounds like enough to keep my evenings busy this week!
I will also get a chance to replace the aluminum trim around the seat.
Thanks again for your help!
Cheers,
Paul
Cheers,
Paul
