Ok. That makes sense. A hook up point for the mityvac.it's a fitting that BMW uses to connect to some sort of dealer auto bleeder machine. IIRC, you can put a standard bleed screw into the top of it after you unscrew the top bolt. After that, you have a normal bleeding procedure....
Sorry that i can't give you any pics.
You can also completely remove that part and replace it with a standard bleed nipple.
