Tranny woes
dadodirt
Bike-2001 R1150GS
Miles-78,500
Symptoms-Low speed rattle of transmission. Sounds like first and second. Not slipping out of gear, yet.
Question-Where is a good place to get a rebuilt transmission or where is the best place to send one to be rebuilt.
I have a local BMW wrench doing the removal, installation. He will need to send it somewhere.
Thanks in advance.......
Have him contact Tom Cutter (tpcutter@aol.com) at the Rubber Chicken Racing Garage. Tom has a reputation for doing it right.
What indication do you have its the transmission? Have you drained and checked the oil for contamination? I dont know but it sounds to me more likely its a clutch problem. :dunno
No, I haven't drained it yet. It has a small leak, tranny fluid.
If it was a clutch problem the sound would most likely go away when the clutch lever is not being touched. The sound continues after clutch is let out.
Bike-2001 R1150GS
It might depend on where you are. There are a handful of good independents who do tranny work. I do this work and have a couple of 6-speed parts trannies for donor parts if needed.
Probably no one does a lot of 6-speed work because it's rarely needed. Stripped input shaft splines are probably the leading cause for opening up a 6-speed, unlike the 5-speeds which have to be opened up for worn internal parts.
Well, after a warm up and drain of the transmission there are small chunks of metal. Looks like another transmission.
New question
Find a used transmission, have someone rebuild the existing transmission, or purchase a factory rebuild.
