PGlaves
#13338
OK, got the Michelin tubes and gave it a try. Installed tubes and tire on front wheel, put the air pressure to it and I think bead has seated, I think. The bead moved out to the rim all around the tire and it looks like it traveled out evenly but, there was no loud POP like I expected. So, I deflated the tire and squeezed the tire all the way around between my knees as hard as I could and I couldn't get the bead to push inward anywhere around the tire. My question is can I assume the bead is seated even though there was no POP? When seating a tubeless tire with an inner tube installed would you always get the POP when the beads seat?
I really want to learn as much as I can about the art of changing motorcycle tires myself because beemer dealers are few and far away and off brand shops are not looking good especially where I live as in there just aren't any and they do not like to work on beemers. The local Yamaha dealer told me he not only doesn't work on them but he doesn't stock my tire sizes and he doesn't like to install tires that he didn't sell. Then he tried to sell me a Yamaha
It doesn't always pop. If properly lubricated it can just quietly slide into place.
There should be a moulded ring visible near the wheel, all the way around the tire which you can use as a visible indicator that the tire is seated evenly.
