SeabeckS
In your case it's probably badly sulfated. I doubt if a cell jumper has cracked. Odyssey are not known for that problem.
Got one of those CTEK MUS 4.3 chargers and hooked it up this afternoon. Bike now starts.
Got one of those CTEK MUS 4.3 chargers and hooked it up this afternoon. Bike now starts.![]()
Good stuff.
I misunderstood your post on page 2 - apologies
Seen the damage from under charging in float mode.
With rare exception, they have been bullet-proof on my 3 BMWs. I had one issue with one PC680 not holding a charge. I sent it to the place I bought it from thinking it was defective after only one year. They load and bench tested it,said it was fine, and sent it back to me. Their tech guys recommended switching from the Deltran battery tender I had been using all along to the CTek MUS 4.3. They charge at a higher rate in their "snowflake" mode, and I bought 2, and have no issues since.
The CTEK charger I got was the CTEK (56-864_ MUS 4.3. Best price ($67) was on Amazon...
http://www.amazon.com/CTEK-56-864-A...&redirect=true&ref_=oh_aui_detailpage_o00_s00
They have a snowflake mode which is recommended for AGM batteries that maxes out at 15+ volts (desulfation mode) before it goes into float mode. Different than "bring-it-back-from-the-dead" mode, and recommended by the folks at Odyssey.
This came from Bruce R. Essig, ODYSSEY National Program Manager.
"Larry –
In follow up to your telephone inquiry about charging the ODYSSEY PC680, we highly recommend the CTEK MUS 4.3.
Use the snowflake charging setting for ODYSSEY. This charger also works on all other types of batteries, wet, gel, etc.
Make sure you use the snowflake charging setting on ODYSSEY batteries.
Let us know if we can help further.
Bruce R. Essig
Office: 660-429-7506
Fax: 660-429-1758
Cell: 816-668-6676
ODYSSEY Batteries are Awesome!
I have run MotoLights, EuroLights, 2 sets of Gerbing's heated gloves and coat liners, GPS, headlight and the heated seat simultaneously with no problem as long as I keep the revs up...
When sitting in stop and go traffic, I'll shut down the Euro lights, heated gear and seat which draws the most juice, then turn it all back on once I get moving. 2,000 rpms +- is the target to hit to charge or discharge your battery. Once discharged, it takes a while running to top it off, even with the revs up high.
Also, even though some battery tenders indicate a battery is topped off, the CTEK does a de-sulfation mode, which really maxes it out. I don't think the Deltran did that, and that's why I switched. There's a big difference between a surface charge and a full charge. It could be that your battery is getting a good surface charge but the Deltran is not de-sulfating the plates.
As always...YMMV.
No worries!
Hopefully this CTEK will do a better job than the Battery Tender. OTOH, winter is over (and so is our new home construction) so a lot more riding might help too!
Cheers!![]()
More riding! More better!!
It may sound too simple but- did you try plugging the charge into another outlet?
In this age of GFI's being in line first- or last
Then we can add the new arc-fault or put the GFI's & AF's together......Things can get kinda sensitive, especially to a charger.
Any chance the battery hookup polarity was wrong? The Battery Tender includes a sense circuit that requires at least +8V DC on the output leads before it will turn on..............As our story ended last time, I had purchased a Schauer Charge Master CM6A charger to keep my very picky PC680 battery properly charged up. This charger is "approved" by Odyssey. It worked fine when I took it out of the box. One month later, with the battery and the charger having been sitting separately (not hooked up) on a shelf in my garage, the charger will not work. No fan running, no voltage output at float setting...........
And here I sit with a cheap, 6 year old Panasonic battery and a 7 year old Battery Tender Jr...and no issues whatsoever. I feel kinda left out.
And Seabeck, where do you live that you need to have a generator at the ready to provide power - Buenos Aires?
And here I sit with a cheap, 6 year old Panasonic battery and a 7 year old Battery Tender Jr...and no issues whatsoever. I feel kinda left out.![]()
Sometimes it's worthwhile to pop the cover off of a dead charger and see what needs fixin'.
They're often not very complicated, but the sensing/regulating circuit may make it a loss...
Even those that proclaim "No User-Serviceable Parts Inside" are worth a look, if you have tech skills, a DVM, and a soldering iron. (Over the years, I've found many items with fuses soldered in inside.)
I've fixed two bad switches and a blown diode, and one had a bad input surge protector (looked like a blue disk capacitor) that had opened; got a replacement at the local electronic parts store for a buck.
Seabeck was one of the first communities in western Washington. Hence all the power grid is old, overhead, and prone to damage from all these darned trees falling over. If ya live in Seabeck, ya gotta generator.![]()
For 7 years in the 1970's I lived over in Brownsville and I know very well where Seabeck is and you think you need a generator? Huh???
