sambler
I've owned a 1995 R100RT for a several years and I ride it monthly or so. The bike has 29,000 miles on it and has been well cared for, cosmetically. Early on, I had some clatter from the rocker arms, so I inspected things carefully while adjusting the valves. I found that the roller bearing cage had been destroyed on the right exhaust rocker. Bearing rollers were coming out of the split in the rocker arm clamp and a couple were laying in the valve cover. When I went to the left cylinder, I found the same issue with the intake rocker.
I ordered new rockers with bearings from Max BMW and installed them. Once I overhauled the carbs, got the proper jets put in, the clip at the right location on the needle, and the valve gap and rocker shaft endplay adjusted, the bike now runs well. However, there is a loudish clatter, almost a knocking, from the right cylinder.
I recently took the bike on a day-long 200-mile jaunt at 65-70 mph and everything went smoothly, as long as I don't care about the noise. I have checked all the settings and everything is spot on.
I don't know where to go next. Any thoughts from you guys? Appreciate any thoughts you have!
