I have a 2004 R1150R with 40,500 miles. The tail light fuse keeps burning out (second fuse, 4 amp). Brake light still works (different circuit).
I had hyperlights installed and removed those. Fuse stills burns.
The R1150R has a front 5 watt parking light on the same circuit. I replaced the bulb and the fuse still burns.
There is difficult access to check the wires for a short. I can't find any noticable frayed wires. I also cut the factory over tightened zip ties around the wire harnesses near the sterring neck.
There is one other person on the R1150R.net who has been dealing with this problem for 2+ years now and has yet to find the solution.
Has anyone here had the same problem?
Any ideas?
Thanks...
Doug
Any ideas?
Thanks...
Doug
