froggy
I am having to surgically remove my trans on a 02 R1150RT. I will be replacing trans shaft, slave cylinder,all seals,and installing a spacer on friction disc to push hub out so all of splines are in contact. At 34000 miles it's hard to believe the splines were shredded like this. Some of my Gateway cohorts state I should realign the trans. How can you realign it if it's already been pegged. Has anyone heard of this?
Thanks in advance
Thanks in advance
