Good evening,
I’ve been a member for a while but haven’t been active on this forum. I’ve posted a similar query on the Pelican R1100S site. The general consensus was I should just ride & keep checking. I’ve also search this site but haven’t found definitive answers.
My motorcycle is a 2001 R1100S which I’ve personalized for touring. It currently has about 28,000 miles (44K Km) on it. I intend use it touring on the west coast - It’s currently stored in Vancouver.
A spline inspection last year showed a slight increase in play from the year before. Estimate movement is less than 2mm at the outside of the clutch. I’m assuming that spline wear is within tolerance – I’ve not hard on components.
I’m favouring an inspection & spline lube before riding. Assuming the splines look OK, can you advise as to how far I should go with parts replacement?
Specifically,
Is it advisable to install a modified friction disk while I’m in there?
And is it better to replace the complete clutch pack even if the parts look good?
Should I replace the clutch slave cylinder or is a seal kit OK?
Here’s a picture of the bike in question,
Thanks in advance, Charles
Specifically,
