08RT, 46K
I have not posted in a bit, but feel compelled to ask for a little help. I am quite mechanically inclined, as I pull all my services myself, but I have run up against a wall.
Last march I took a trip to daytona and got caught in some heavy traffic. Bike got warm, but not to an extreme. With the clutch pulled and in 1st gear I revved and heard a soft knock from the left side. I was worried I had gotten it too hot and desperately found a clear lane to get some air moving. Bike was sluggish. When I arrived at my destination the noise continued. I rode to the BMW dealership in Daytona and got the tech to come hear it. Wouldnt you know, no noise. I told him let it idle for a bit and it will start. He told me just dont get caught in traffic and dismissed it. Hmmm!
I bought a set of plugs thinking I may have fouled a plug or closed the gap, and the bike was running oddly on that cylinder, causing the knock. Old plugs looked OK, but I replaced them anyway. Bike ran great, no knock, I was very happy.
A month ago, the soft knock reared its head again. This time I started paying attention to when it was was doing this. The noise seemed most prominent with the bike in gear and clutch pulled. With it in neutral and clutch pulled, the noise was there, but less sound. And with it in neutral and no clutch, it quiets down. So for some reasonI dismissed it as non-combustion related. Prior, I had added a little fuel additive thinking I might have had an injection issue. Noise seemed to go away.
Now its back, and I am worried. It is not normal. Oil has been freshly changed prior. Two changes since the first issue. TB's are in sync. GS911 shows no faults. Valve lash is good. Bike is smooth as silk when cold, but if it gets above my normal operating temp seems to exibit this problem. Seems to be a bit sluggish when it starts with the knock issue. I know this is supposed to be a bullet-proof motor (to a point), but I am not familiar with the internals, and really dont want to be until I have no option.
My only guess at this point is a sticking injector causing it or carbon knock. It is rotational with the cycle of the crank, or so it seems. Noise has not increased in intensity since its start in Daytona. What about a bad coil pack? Could the coil pack be affected by heat?
Any input with this would be greatly appreciated. Until then I'm riding it and still listening for something I can pin point. Hopefully I've given enough info. Any questions please ask. All input is appreciated.
Thanks,
Jim
Thanks,
Jim
