Anyname
Active member
In a recent thread, Kevin Greenwald mentioned the following regarding a rider induced low side:
"Finally, if cameras existed for every curve on every road (I know - the conspiracy buffs out there already believe they do!), this would just have been Video # 1,575,433 of what 'Front Brake Only,' or 'Two-finger Braking,' or 'Rear Brake Only' results in."
I get that it's best two use both brakes, but I don't understand problem with two fingers on the front brake. I used to commute on heavily traveled roads in eastern Mass. where random panic stops were common. Typically, it was also not possible to have a decent cushion either in front of or behind the bike. My drill for dealing the panic stops was a) try to always know where the following vehicle was. b) brake as hard as possible (having my fingers already on the brake helped with the reaction time) and c) dive for the space between the two lanes of traffic. More than once I was nearly stopped before I could implement step c. This meant that I needed to have good throttle control to regain forward motion.
Two finger braking seems to be an advantage due to no time being lost in transitioning fingers from the throttle and brake. For the same reason, I try to adjust my rear brake pedal so that my foot "covers" the brake. I will add that I do practice panic stops and under controlled conditions I don't find it difficult to stop hard enough that the front tire leaves a black mark on the pavement.
So, what's the downside to my strategy?
