flash412
Loose Cannon
"There is no better lesson than the knowledge one gains when one f#$%'s up." - Wayne Millerlorazepam said:slide the heat shrink tubing on before soldering the wires or you will do it twice.
flash412 said:Two years later, black tape adhesive tape fails and tape falls off, twisted wires touch frame, blow fuse, motor dies (or refuses to start).
For a more permanent solution, solder the two wires together and then cover the joint with heat-shrink tubing.
Them whats don't are the folks with NO binniz modifying their electrical systems unaided.breyfogle said:Not everyone knows how to solder or use heatshrink-tubing.
flash412 said:"There is no better lesson than the knowledge one gains when one f#$%'s up." - Wayne Miller
lorazepam said:Veg, The ST I have has that stupid retracting sidestand. I sure wish I could put the sidestand down comfortably without having to get off the bike. I would love to have a stand like the RRS has vs that stupid spring loaded pos.
