That might be the issue. I had them done and the bike was running great for 99% of my trip. It was on the last day that I started to have issues. However, it's hard to narrow down my problems to just the valves since there were a few things that needed to be looked at. The bike is done and I'm just trying to get in touch with the service department to find out what their "recommendations" (as the voice message said) are.
The tech gave me the specs last time but I didn't think to look at them. I will ask for the same info this time and probably double check it myself. There is one tech at Bob's that primarily works on old K bikes. I have talked to him before and seems more than competent.
Lee: Just so I have it clear, tight = less valve clearance and loose = more valve clearance right?
And the fact that they are only doing 5 proves that they don't understand (or care?) what they are doing. Yes #2 intake is technically within spec. (.006-.008"). The fact that they have to change all the others but not that one means that they have a "close enough attitude".
Ugh... this is the reason why you should do the maintenance yourself.
I got the bike back tonight and it is running ok. Here is the new specs of the valves (this is based off of the tech notes):
Cyl 1 Intake:
measured clearance: .25mm
old shim: 2.4mm
new shim: 2.35mm
new clearance: .30mm
Cyl 1 Exhaust:
measured clearance: .20mm
old shim: 2.5mm
new shim: 2.45mm
new clearance: .25mm
Cyl 2 Intake:
measured clearance: .20mm (in spec no adjustment)
Cyl 2 Exhaust:
measured clearance: .23mm
old shim: 2.4mm
new shim: 2.35mm
new clearance: .28mm
Cyl 3 Intake:
old shim: 2.4mm
new shim: 2.35mm
Cyl 3 Exhaust:
measured clearance: .063mm
old shim: 2.40mm
new shim: 2.15mm
new clearance: .31mm
I have not confirmed this yet but I will check them tomorrow myself.
That's not even in spec. for the intakes let alone the desirable setting.
It's very obvious they have some issues with their technicians (and I use the term loosely). They can't even read the manual let alone set the valves to the optimum setting.
That's pretty bad since they knew they screwed up the first time to screw it up again. That's attention to detail for you!!!!
I sure hope they didn't charge you for doing it wrong----AGAIN!!!
Looks like Bob owes you a couple of free shims![]()
how many miles are on this bike?
The MAJOR problem was the #3 Exhaust (it usually is).
That's not many miles.
I shimmed 5 valves on my '94 K75RT this week at 59000 miles. I've had the bike since it had about 8000 miles on it and this is the first time I've had to make any adjustment.
Jordan
Any particular reason why #3 exhaust is susceptible?
