krash
So the weather is warm enough where I can change the hall sensor also going to replace the battery...
Any tips on replacement of the hall? It looks pretty straightforward.
My biggest dilemma/issue is setting the timing. The original owner of my bike is a good friend (I was with him when he picked it out at the local BMW dealer). He did replace the hall sensor 10-12 years ago. I'm assuming that the timing was set incorrectly when the dealer installed the new sensor as I do get pinging in 4/5 gear at highway speeds...If I lay into the throttle hard at speed it'll ping even with high octane fuel...
f.yi... Bike has 28k on the clock, 24k has been done...Fuel filter and internal tank lines replaced(except for vent lines)...Valves adjusted, TB synch done...New left side tensioner done...
With all that in order, it must be the timing...Any advise on how much and far to retard the timing?
I've read that you could rotate the sensor plate to max retard and the bike would
run fine...Any help would be appreciated.
