k7gle
Member
I understand I should set "race" (fully loaded) sag at about 30% of full spring travel, which is pretty straightforward on a standard two-shock system where I could measure the distance parallel to the spring travel.
The specs for the R11RT list max spring travel at 135mm. With paralever suspension the sag measured vertically between the rear axle and a point on the suspended frame doesn't necessarily have anything to do with the amount of compression of the spring due to the geometry of the system.
So how should I choose a sag setting?
- Glenn
- Glenn
