When I got my R90/6 about 7 years ago I replaced the wheel bearings, Steering bearing, swingarm bearings. Due to an electrical problem, the bike is up on my lift getting the shakedown. In going through various things I happened to give the rear wheel a cursory shake an noticed that there appears to be some lateral looseness in the rear wheel. Manual states that the torque on the axle nut should be around 35ft/lbs.. I tightened to specs and there was still wobble. I figured that since it is up on the lift that I should see if a greater torque would tighten it up. 45, 55, finally about 70ft/lbs and it felt like it was good. Not so fast, there is still some play. The wheel turns smoothly as if the increased torque has no effect on it however 70ft/lbs will probably screw something else up once I get it out on the road.
It has been 7 years since I have been in there and my memory of how it is suppose to work is not clear. Should I assume that the bearings are bad? Or is this a problem of not having the proper bearing stack height from normal wear? The bearings are probably available locally but what about the shims?
Basically, since I haven't torn into it yet I don't know what questions I should ask. Anyone got some good advice on this one? By the way, tomorrow I'm going to start to pour over the Snowbum article on bearings.
