anotherbmw
I think the rotor is mounted properly. I used a new bolt and tightened to spec. The wobble almost completely goes away at rpm above idle. But check out the pic, looks like a leak behind the timing cover, could that be the front seal and related to this?
The bike as verified 45k miles. I have the original owners manual with maintenance records back to day 1. I picked up the bike in September 2017 after it had not run much in 20 years and did the usual (main engine seal, push rod seals, forks, etc.). It also needed a head bolt helicoiled in.
