YOCKYRIDES
My 83 R65 has had a strange problem where the oil filter cap leaks at times. The mating surfaces are perfectly clean, the gasket, o-ring and spacer ring are properly positioned. The cap has been replaced twice and isn't warped. The 3 mounting bolts are fine, no stripped threads. The screw holes are fine, everything torques up properly.
A double gasket has worked but that can't be the real solution.
Any ideas on root cause and solution?
