I appreciate all of your advice and help on this matter. Here is what I devised to accomodate higher bars. I did position the bars above the triple clamp and then made a cross bridge out of alum. angle,1/8th X 1 1/2 by 3/4". I meausred the distance between the bar mount base holes, where the alignment pegs held them in place, and drilled the holes exact. On the upper triple clamp there is a treaded hole
that has a set screws in it. These set screws can/do hold the alignment pegs securely in position. Remove both set screws. If they are frozen in place like mine were, you can use an Easy-out or a drill bit of slightly smaller diameter to drive them through
and out. I used a tap to assure the treads were good. Cutting the length of the alum. angle must be precise as you want to take your time to make sure it is not a losse fit.
This will eliminate any play that can work into a moving joint and cause an unsafe condition. In my case, the bike came with a crossover bracket system for a Garmin GPS. This aids in securing the placement of the bars and assures a safe riding experience.
So, I have three seperate areas of securing the bars:
1. The bar clamps
2. The alum. angle crossmember, fabricated
3. GPS cross bar mount
Do not feel that the bridge and clamps are enough. Arrange some other securing method to make sure your life is safe when riding. It could harm others. Get professional help from a machinist or simple pay the money and buy products that are already on the market. I am in no way,responsible for your actions.
Here is a photo of my setup.
1. The bar clamps
