LuckyGrownup
Can someone check my work here ? I am trying to figure out how fuel lines are supposed to be configured just incase one of my lines got plugged in the wrong way.
It appears the high pressure output is on the front highest point on the RT tank while the high pressure input to the fuel regulator is the lowest point on the regulator feeds.
Possibly Critial information: The last day I rode the bike I rode it 15 miles on reserve. The air temperature was about 20F. I put 2 gallons of gas in it after riding for 15 miles on reserve. The bike sat for a week and a half.
The fuel strip works and displays 2 bars.
Millage: 88K-89K
Year: 2002
Model: R1150 RTP
The long winded Back story:
Last year, I replaced the motor on my R1150 with an ebay motor. I have 5000 miles on the ebay motor. I recall having an issue with the suspension when I put it on. I messed up the front shock. I thought I could turn the rings on the bottom of the front shock to make the shock smaller. It didn't get smaller but I eventually got it on. Well recently, I had fork leak so I took the old R1150 to a Sport bike supension guy. He rebuilt my front shock and while it was there I had my Ohlin shocks rebuilt. After the suspension guy buttoned everything, up the bike wouldn't start. Since the guy didn't specialize in BMW bikes, I didn't get upset. I just had AMA tow the bike home. I was told the bike would start on starter fluid, but the suspenion guy thought the injectors were not firing. I removed the tank. I checked wires. The electrical stuff looks good. A 9v battery will cause both injectors to click, but they are not fuel getting since I started messing with things. I hear the fuel pump prime upon turning on the key. And if I pull the fuse for it, it stops. But either way, I have no fuel pressure. I even doulbe checked the fuel lines to make sure they were not put on backwards. Anyways I have 0 PSI in every way I plug the fuel pressure gauge. So, I ordered an aftermarket fuel pump from beemer boneyard. The stock fuel pump is twice the price. My fuel pump seems to make a spinning noise. The battery is over 2 years old.
Millage: 88K-89K
Year: 2002
Model: R1150 RTP
