K-bike questions belong in K-bike forum.
Fact you own an Airhead is pretty irrelevant to your question, right?
I'm assuming you have the stock 2 hole dash.......remove windscreen, loosen dash panel, carefully insert hands up into the tight access....disconnect battery first!!!
Removing the headlight assy can give you more room too I believe...I have a 4 hole dash, the gauge access is a real PITA
