globalrider
Alps Adventurer
In many cases it seems true because to diagose something, you need an understanding of the system.
You just gotta love YouTube when someone has a vehicle issue and countless viewers post recommendations for “the fix”. Generally there is one fix, not countless fixes.
Anyway, in the video I am watching, he is reading off a list of all the viewer recommendations that he tried and also with the solution at the end of the twenty-plus minute video.
Having to watch the balance of the twenty-plus minute video to confirm what I was sure the solution is after viewing the first minute describing the problem was frustrating. The vehicle would not start unless it was being cranked for well over ten seconds and only after giving it full throttle. This on a warm engine that was left to sit for several minutes prior to a restart. Sure enough, at about two-third of the way through the video, he is doing a fuel pressure test. Pressure was fine, but pressure was bleeding down fast once the ignition was off.
My guess during the first minute of the video: your check valve in the fuel pump is shot and the fuel pressure gauge at shown later proves it. Of course it could also have been a faulty engine temperature sensor which was mentioned but not countless other parts. But his video shows a “$5 Fix”. I never knew you can replace countless parts for $5.
Mentioned he should diagnose the issue instead of being a dealer or shop “parts replacer” and some of the viewer recommendations didn't even make sense. I won’t bother repeating his reply.
As for the $5 Fix, with about 150 videos, that just suckered viewers to click on it, much like the sensationalizing we see in the media.
