olironrider
Member
1978 R100RS. I'm down to installing the 11 42 1 335 387, Tube, into the filter canister bottom/crankcase.
It appeared that the original non-oil cooler filter tube (short), was installed "bottomed-out" in the threaded bore of the crankcase, perhaps with "white lead paste" sealant. I fabricated a tool to remove it and did just that perfectly.
My question is: it appears that the long tube should be installed "bottomed-out", in order to compress the filter gasket rubber ring at the crankcase end, as well as compress the large black o-ring and filter against the thermostat housing?
I'm thinking someone running an "oil cooler" model might know; better yet, is the outer end of the tube "above", "flush" or "below" the crankcase parting line?
Yes, I have done the "$2,000 O-ring Calculation", arriving at a 22% compression, using the gasket, o-ring and shim. Additionally, performed "Revision A" to the right header for clearance to the thermo housing.
I'll check back later... donp.
