I have a 1993 R100RT with 60,000 miles. I have replaced pushrod tube seals, front main seal and valve cover and crankcase seals. I have purchased tools from Cycle Works and I want to replace the oil pump seal, the rear main seal and clutch plate as mine is less than 4mm.
I know I need to order a clutch plate and five bolts to bolt on the flywheel.
What else should I replace? Do I need more clutch parts? Do I need new bolts for the oil pump cover? New bolts to hold the clutch together?
I bought rear main seal and "O" rings from Cycle Works and I am confused if they should be soaked in oil before installation.
I don't have a dealer (and can't afford big $$$ for repairs) so I am thankful for the advice. BTW Clymer's is not that great.
Thanks,
Campbell Tellman II
Thanks,
Campbell Tellman II
