I have a 2004 R1150R. As you know, the battery is buried under the tank. I have a lead running from the battery with a SAE connector. I use it to maintain the battery and periodically take readings with my meter. Recently, I was unable to get a reading although the bike started easily. It seems the lead is loose at one of the battery terminals. I've removed the tank a few times for the joyous task of brake fluid flush/change. Another time, I just propped the tank up at the rear to inspect the battery. I forgot which fasteners I removed to allow this. Yes...I could figure this out. But...I'm a lazy guy. I was hoping not to mess around taking everything apart, and just get to it. I searched for this info and found nothing. Do any of you have that info at the top of your head or maybe have a link?
