BMW is switching to Shell from Castor to produce their oil. New bottles and names. $7 a bottle to dealer, $14 msrp.
Just a reminder of what I think is the best deal for oil if you want the closest to the BMW brand:
http://www.amazon.com/gp/product/B008MISDH4
Comes out to a bit over $7.50 a quart and meets the JASO MA2 standard so it can be used with all the new bikes.
The 20w50 version of this oil was mid-pack at best in the March 2013 oil comparison article. It was not up to the ZDDP levels that the Spectro or BMW oil tested at the time. In 2013, BMW's oil was blended by Spectro and the results seemed to show that.
Those WalMart shoppers endeared with Rotella will find this isn't the same stuff. Manufactured in Dubai.
And just how important is ZDDP for those with overhead cam engines?
I'm not really too concerned with the "best possible" oil for modern BMWs. I haven't heard of many engine failures from using oil without enough ZDDP. As has been said many times before, is the best oil is the kind that is changed on schedule.
Does anyone want to talk tires, too!!
I hear this argument all the time and laugh every time I hear or read it. An engine does not need to blow up to suffer from inadequate lubrication. I do know of a few cases where camshafts needed to be replaced, and a few where cam followers needed to be replaced. Not to mention the need for new rings or the need for valve guides or rod or main bearings. These are all wear related items that benefit from or suffer from the quality of the lubrication.
You have a good point, however I still contest that using the basic specified oil by BMW is perfectly sufficient to maintain it and have many happy miles.
I agree completely that following the BMW specification is "good enough". What I don't agree with is using car oils that fail to meet that spec; or using a diesel oil that fails to meet the spec but is cheap, etc.
I personally do not and never have used synthetic oil in any of our several BMWs. I don't disaprove of synthetic oils - I just don't happen to have any motorcycles or cars that need them. If I had an Airhead today I would be using a synthetic oil in it because of the wide temperature variation and high temperatures at which they operte. But water cooled F or K bikes and even Oilheads don't see these operating conditions unless they overheat. Then it is time to change oil immediately.
Always remember:
Good oil is better than bad oil
Clean oil is better than dirty oil
Some oil is better than no oil
