Welcome to the forum! I'm not familiar with the type of oil filter you have and how it installs. On my Airhead, I can't "fill" with oil as it's a paper wrapped filter assembly and it goes in sideways. However, on every car/truck I've ever serviced, especially those that install with the threads up when installed, I've filled them will oil and let that soak in while I do other things. Then come back with a final topping off along with a wipe of clean oil on the o-ring before putting the filter in place.
It goes in vertically but there is a messy bit of spillage when a klutz like me does it-HaHa! Any one know where the oil goes after it is pumped through the oilhead filter?
If you're really making a mess, an alternative might be to install the filter only partially filled , add 3 or so qts of oil to the engine, pull fuse #5, and crank the starter for 30 seconds or so or until the oil pressure light goes out. (Then add the remaining oil.)
ragtoplvr;1089539 As to why there is no drainback valve said:Because it is at sump level there is no valve required
From the pump oil goes directly to the filter and then to the main crankshaft galleys and then out to the heads. So, when possible, filling the filter is helpful. It speeds the oil reaching the lubrication points. I always fill Oilhead and Classic K bike filters.
My biggest concern with even just several seconds of no oil pressure isn't lubrication. It is cam chain slap which is that clatter you hear until oil pressure rises.
It's a wasted day if you don't learn something new... - Bob
