Oil fill O-ring
craydds
Member
My oil fill cap is weeping a little oil. Stock BMW o-rings are $4.21 apiece, part number 07-11-9-904-950: https://shop.maxbmw.com/fiche/DiagramsMain.aspx?vid=60124&rnd=09082020 .
At $6.81 for 25 o-rings (27 cents apiece) I am going to try these from McMaster Carr: https://www.mcmaster.com/products/o...t~metric/width~3-530mm/width~3-500mm/od~32mm/ . Had to pay shipping plus tax, total came to $17.15, but that is only 68 cents per o-ring. I specifically chose 3.5 mm thick (diameter) o-rings, maybe get a better seal. Will report on results.
Have you tried the local hardware store? Midwest Fastener selection.
I like McMaster Carr but sometimes the quantities don’t work for me.
Omega Man, I did not try local. Sometimes they do not have specifically required items. Often it is easier for me to go with McMaster, and I can get exactly what I want. Yes, I usually get a lifetime supply. Ha! Now I will have a lifetime supply of o-rings. Anybody need one?
p.s. Recently ordered a box of M5 "clip-on" nuts; box actually had a BMW part number! https://www.mcmaster.com/catalog/129/3613/95210A350
I posted this in another thread-
And even with round and square edge, sometimes I need something else- :dunno
Take your old o-ring to a good hydraulic jobber/repair shop. They can usually match sizes in a variety of materials.
Best,
DeVern
DeVern, we have some good local shops. It's so much easier to lay on the couch with my laptop and place an order. Don't have to run around town in traffic.
:D
Well, that’s my usual technique, too! But I end up giving away a lot of o-rings as bikes come through my garage, especially on Tech Days. And I like to visit my local hydraulic jobber every now and then, if for no other reason than ogling his assortment of cutaway examples. ;)
Best,
DeVern
pics
stock size on left is 27 x 3.2 according to Max BMW; that's 27 mm i.d. x 3.2 mm thick o-ring. McMaster on right is 25 x 3.5 and visibly "fatter":
package of 25 o-rings at 68 cents apiece:
good seal so far
thicker o-rings drop right into place:
looks good so far, and I've tried to run the bike hard and get it plenty hot. will continue to monitor:
packaging:
One thing I learned the hard way, My o-ring was weeping a bit on a trip so I snugged it up a bit. After 350 miles still weeping. Stopped at ACE and put a ring on the top part of the filler cap (until I got home). Turns out if you overtighen the cap the ring will leak. Who'd of thought. Never leaked again.
I actually think that is an excellent consideration. :thumb
Great info!
Metric vs Inch o-rings
I was searching for the stock size 27mm x 3.2mm and not finding anything. So I tried converting the measurements to inches and "voilà"... 1-1/16in by 1/8in. Lots of options. (size #211)
Correction: After ordering a bag of size #211 Viton o-rings, #211 is NOT the correct size, they are too small. The 27mm must refer to the ID not the OD.
follow up
I did a little 250 mile ride yesterday - up to Cloudcroft, Ruidoso, and back. Zero oil weeping, "fatter" o-ring seems to work well. Now we shall await a long term report. How many miles/months will the o-ring maintain the seal?
One must use only METRIC parts on a BMW. :german
A 1/2 inch wrench could conceivably be used instead of a 13 mm, but this would upset the balance of the entire universe.
