K
kayseventyfive
My oil fill plug is weeping a little oil, which attracts dust. Is there an inch measurement O ring that is a good substitute? I like to use Viton O rings for problem areas, but the size (25 X 2.7) does not seem to convert well.
Or should I consider removing a little material from the sealing surface of the cap to compress the OEM seal a little more?
