jconway607
JohnWC
My 96 R1100 has never had a problem with the ABS. The last Odyssey was about 4 years old. I put a new Odyssey PC680 battery in it last fall and I keep it on a trickle charger all the time when not riding. Now every time I start up, the lights are flashing alternately, and stay that way. It also seems to crank slower. If I stop the bike after five minutes of riding, then restart it, everything works perfectly.
The people at Odyssey seem to blame: 1)battery sat on shelf too long, 2) trickle charger doesn't work, 3) bike's charging system not working right, 4) my Fluke meter is inaccurate. Everything but the battery, and all rather a stretch as far as I can tell.
My point is this: The battery reads 13 volts before I go to start it, which according to Odyssey is fully charged. (12.84 volts from them) Now I said to them, " But even a battery that is about shot will read 12 volts. It's the amperage that goes down." They seemed confused by that.
I look to everyone here for expertise. Does the ABS only consider the voltage? In which case I can't see why it's showing a low voltage fault on start up. Or would a battery with proper voltage but low amperage cause the fault? Any other ideas on this situation, or how to fix it? Thanks.
