The safety bars (BMW's description) aren't that difficult; a nuisance, perhaps, but not onerous. Only adds a half hour or so to the disassembly. Besides, they must come off to remove the tupperware. The safety bar base support system can stay where it is, as can the support rods under the cylinder heads.
As I recall, the exhaust system has to come off if the belt cover has not been modified by cutting it in two. Exhaust system removal is also not a big deal as long as you remember to disconnect and clear the O2 sensor harness first!!! Order up a new alternator belt and exhaust gasket rings!
I noticed your mention of a 'timing cover'. All that's in there is the alternator belt and the ignition system trigger which is all but hidden by the pulley on the end of the crank but is probably worth inspecting.
Are you using one of the dealer's on-line fiches for visual reference? I prefer the Max fiche.
It's not as frustrating working on the RTP up here in the Great White North, where the riding season is suspended for at least four months of the year by frozen white fluffy stuff on the ground and where the shop is insulated from the cold.
I get the privilege of clutch duty on the pig next winter. Oh Joy!
