two more nagging problems
Before I start on a course of action, there are 2 things I would like your opinions on.
1. The left lower cam chain blade came out when I took off the head and removed the front bolt/pin holding it. After looking at the schematics, it appears the other end should have been secured also with an Eclip/circlip on a shaft. I saw a video of it also with the piston and rod removed from a rusty engine. BMW says reinstalling it requires splitting the cases, the video said it was possible to put it on with only the piston removed.
Not knowing any better then, I reinstalled it as it came out, so it's just against the locating pin, perhaps on top of it. Funny, the front hole in the blade is oval and wide enough to locate it either way. Edit: actually it appears in the schematic that the other end has the oval hole in the blade, sorry.
This is a nagging worry, what do you think. Is it important enough to disassemble the whole motorcycle? It was obviously assembled wrong and had been running that way.
2. The lost cam chain tensioner piston. The original 17mm head tensioner piston slid off upon disassembly and fell into the case along with the spring. I was able to retrieve the spring, but the piston it MIA. I drained the oil in the faint hope it would come out, and peered and poked inside the case with a pick-up devise, no luck..so same thing, forget it or disassembly bike. So..........what do you think.
