With ABS there is an extra DIODEI-RELAY (part #61367662056, bobsbmw.com). A bit cheaper on ebay.
It contains two diodes which separate the front and rear brake switches and also connects to the ABS control unit (input only). It is the green colored relay shown on this page. Pin #4 of the relay is the 12V supply to the rear brake light.
/Guenther
Hi Guenther
Do you happen to know where this relay is located?
I did trace the taillight wire up to the front of the bike but still no luck without tearing into the bike further. I did end up making a temporary run to the taillight so I could do my shakedown trip last weekend and everything went very well. I did discover that someone had reversed the spade connectors at the taillight so got that squared away, also. Sounds to me like that relay might very well be my culprit. I made an offering of a few turn signal lenses to the off-road gods so I need to place an order anyway so I can order up the relay.
Thanks!
