Happy Thanksgiving guys and family,
After reading a article on the swing arm and bent frames, I thought that I would take a look at the output shaft of the transmission.
I have just finished doing the spine lube and all went well, till I move the swing arm back and forth. The output shaft was fine, no rubbing.
In the process I pulled the spines out of the finale drive. The shocks are still installed and thatÔÇÖs about it. Am I in deep do-do?
Do I need to take the output bolts out and reassemble? One more, if IÔÇÖm this deep into this is there anything else I should do.
I have enjoyed very much the time, when I can find it to work on the bike, had real good luck, up to now. Thanks to all the airheads that have gone here and know a way back!
Thanks again-
Rob
Thanks again-
Rob
