I just did the 40,000Km (25,000 Mile) service on my 2017 GSA.
Having read all the stuff about the splines rusting, I had lubed the rear splines at the 20K service, so this was the second time I've done them. I'm pleased to say that everythig looked good - no rust on the splines.
But, I have two questions:
Was I supposed to do the front splines as well?
And, with respect to the front splines, I am assuming it is correct that the shaft slides back and forth on those front splines - to some extent? The shaft would not (easily) pull off those splines, but seemed to move freely about an inch or so back and forth on the splines. Is this correct?
Finally, I know there is now a "recall" on the swing arm/drive shaft where BMW drills a drain hole in the swing arm to try to prevent the rusting of the splines. Sounds like a pretty Mickey Mouse solution to me. Is it worth getting it done if I'm diligent with lubing the spline(s)? What are people's thoughts?
