Fellow airheads, I am a new proud owner of a 1982 R65. This is my first motorcycle so I am not entirely sure what I am doing. I live in the Manassas, VA area. I got an aerospace engineering degree and have no idea how engines work, so here I am. Besides this project, my free time is focused towards skateboarding and rock climbing. Im interested in meeting other airheads so let me know!
Here is a picture of the bike:
A quick description (from seller):
16000 Miles. Features upgraded Marzocchi shocks, beefy K100 Forks, 34mm Vikuni VM Carbs. Bike has been serviced including: top end refresh, valve adjustment, final drive service, carb sync, etc. (but I am assuming none of these have been done).
I got this bike from a little shop in DC. Owner said it has been sitting for a long time.
Current things I have done:
Valve clearances - these were completely closed on the right side
Check spark plug arcs
Empty and fill fuel system - there was leftover fuel
Carb clean
Here is where I'm at right now:
The bike is able to start with Enrichment: ON.
Idle backed out: 1.5
Air mixture screw out: 1.5
However, I need to give it some throttle and rev to about 2-3k rpms to keep it alive.
If you notice in the video, the left side is popping and there is light coming from the intake side. What do you think is causing this?
You can see the light coming from the intake here. Is this the arc from the spark plug (misfire) or actual combustion?
Carb clean
