Need to Replace Master cylinder
dougjordan
Don't think it is worth rebuilding a second time, bore a little big 14.6 mm and a little pit where o-ring sits. ATE under tank. So guidance on where to buy based quality, I know they will be after market. Keeping it under the tank is what i am looking to do ...
Check out the link in my signature line. In the Wheels and Brakes section are a couple of rebuilders...I've heard good things by others about Apple Hydraulics. They can reline the old master cylinder...and I think they use a brass insert so that corrosion issues going forward are greatly reduced. Nice thing is you get to keep your current unit!
Thanks I figured it be sleeved , didn't know where.
