watermelon
Member
I have just one short route with just points at the beginning and the end on it. It seems that there should be less than 87% used up. Is that normal and maybe that the actual routes don't add much?
If you loaded all of the maps for North America on it, that 87% could be very true.
You will need to put a SD card into the slot and then you will have all the room you want.
If you are going to use it for music and such.
You are correct as I understand it, that routes are not very large.
I don't know anything about using SD cards. -don't even know where the slot would be. It looks like I got some learnin' to do.
Do what Bob says and delete unneeded files to free up memory.
I would recommend you take the device to somebody that knows its file system. For a person not ready to insert an SD card, deleting files might lead to real problems.
