My 2004 R1200CL won't start, Fuel pump?
djcondie
Member
The bike was running when I parked it last night, now it won't start. It turns over but that's all. Could it be the fuel pump? How can I check to see if it is the fuel pump? Any other suggestions as to why it isn't starting? Thanks,Dave,
Remove one fuel injector, leaving the pipe and wires connected. Aim it at a suitable container and crank the engine. If it squirts robustly the fuel pump is OK. If it dribbles the pump might be the problem.
Does the CL have the square white connector from the fuel plate to the main harness? (below the right rear of the tank on the RT and RS) If that's not making good contact, the bike won't start.
Do you have all lights operational?
Check all fuses; if the CL is wired like the RT or RS, then F5 powers the Motronic (brain) and F6 powers the fuel pump. Each is 10 amps.
After taking Paul"s suggestion, it appears that I am not getting fuel to the injector so I have ordered a new fuel pump. To be delivered next Tuesday.
Before spending more money, you might want to check the fuel line hoses inside the tank. I believe they have a history of deteriorating over time resulting in the symptoms you are seeing.
Since it looks as if your planning on replacing the fuel pump, consider replacing the "U" shaped fuel line that is in the tank with a flexible fuel line from "euromotoelectrics"
It's this OEM fuel line which degrades over time and will cause you grief. Many that appear too be in good shape with the naked eye have cracks in the radius of the hose which may be undetectable until pressure is exerted on it from the inside
https://www.euromotoelectrics.com/product-p/fp-hosekit.htm
A good time to swap out the fuel filter as well
You will most probably never have to go into your fuel tank again
Footnote:
When I replaced the fuel pump on our 1100RT as have others, I changed out this fuel line and moved the fuel filter outside of the fuel tank, it's not visible on the RT as the moved filter is covered by the plastic body panel. Could be different on your bike depending on where you would mount the filter
SUCESS!!! After replacing the fuel pump, fuel filter, and screen The bike started right up. Thanks for all of the suggestions and advice from you all. Dave
