TomR1200
Member
Hello,
I just switched to Metzeler Z6 Interact tires on my 2007 R12R.
Metzeler makes these tires in various compounds, and recommends different ones for different bikes (even different model BMW's). The recommended front tire for the R12R is the "standard" compound ("120/70 ZR 17 M/C (58W) TL ROADTEC Z6 INTERACT"), but the recommended rear fitment is "180/55 ZR 17 M/C (73W) TL ROADTEC Z6 INTERACT C."
The "C" on the end refers to the compound, and according to the footnotes there are about 4 available for the same tire size. Interestingly, the "C" version of the 180/55 ZR 17 tire weighs 1/2 kg more than the regular compund. Both have the same 6.5 mm tread depth.
Does anyone know if the tire compound is designated anywhere on the sidewall? Mine has no "C" anywhere that I can see. Is the "C" softer or harder than the standard compound?
Thanks, Tom
Thanks, Tom
