Map update- Connected app.
BrianAMcPhail
Active member
I found that there is a map update in the Connected app. Not to be confused with updating the app itself. Your phone's App Store is not needed.
Just open the app
Tap the "..." on the bottom right
Tap "map download"
Tap "update all"
Highly recommend log out, restart the app, and log back in when completed.
Hi, I tried doing the map update as it says there are 22 updates to get. When I press update all, nothing happens. First time this occured. Any thoughts? Tried restarting the app and the phone (android) and no change.
So does it still reflect that there are updates pending- or has that message gone away? You might need to update 1 at a time. Maybe it's too much for your connection, or maybe your phone is configured to require WIFI for big files... (which is probably a good config to have on)
Yeah, that's a LOT of data... California North is about 400 MB, and took several minutes on WiFi (5G).
I had to do my map updates individually. For some reason the update all selection in the app would not work, a bloody PITA. Phone settings or connection speed is not an issue as it's worked flawlessly in the past. WTFK, this was the first map update on this app version could be another bug needing fixing.
