I can see a loose wire behind the voltmeter inside my Luftmeister fairing by looking through the turn signal port and can feel it by reaching in through the side opening, but I need need better access to reattach the wire. I read various threads about fixing and replacing voltmeters, but no one mentioned how to physically remove and install them. The headlight in the fairing is the adjustable style and it would seem like I need to remove the headlight and its mounting shell to get inside the fairing behind the clock and voltmeter. But it's not obvious to me how to do that. The shell is spring loaded and pivots up and down on bolts on each side of the shell where it attaches to the fairing. I might be able to remove the bolts, but am not sure I could put it back together with the spring tension, plus there is no room to use a wrench inside the fairing on the nuts. Is there some trick to removing the headlight shell to get into the fairing or is there some other way to access the back side of the voltmeter and clock wiring that I'm missing? Thanks for any help. '77 R75 /7.
