bmwskeeter
I have a 1994 R1100RS that the low fuel light stays on. What is the cure ?
Thanks,
Skeeter
Thanks,
Skeeter
The light stays on with ignition on, plugged in & unpluged.
Pulled relay center back in box #61 35 2306 365 , light went out. Not sure if that is the right one or what it means.
Skeeter
Schematics may be downloaded for a nominal fee on this forum.
http://forums.bmwmoa.org/showthread.php?73592-New-Electrical-Diagrams-for-R1150RT-and-R1100RT
So I've been riding my '94 RS for at least 10 years w/ a constant low fuel light. Not a big deal, just fill up every 120 miles or so. Every tech I've talked to has told me it's the sensor inside the tank and that always sounded like a job to do later rather than now. I finally decided to fix it this week and it seems my procrastination has finally paid off: I found this thread when looking for instructions on changing out and or repairing the sensor, and 10 minutes later I confirmed my relay was bad.
Thanks GSAddict! You saved me several hours, probably some money and I don't have to put up with hands that smell like gasoline for a week. The next job I've been saving for "later" is the hall effect sensor, probably will do that over the Thanksgiving or Christmas holidays. Pls PM me if you're still rewiring those things.
I sure hope you don't get caught in a pouring rainstorm between now and Thanksgiving.
My low fuel light comes on around 200 miles after fill up usually takes 4+- gallons of gas have 6.1 gallon tank, light is supposed to come on 100 miles from empty. Calculate your mpg for several tanks of gas or every tank than keep track of miles ridden and you know what gas level is. Remember there is a reason they call indicator lights "idiot lights" . My bike 1994 R1100RS usually get about 45mpg average.
