Likely a long shot....need heated seat connector
texrt1
Looking for the driver seat connector. If I'm correct....BMW does not offer that part probably since it is part of the heat pad. If someone has a heated seat that no longer works perhaps cut the connector off and I could splice it. The harness for the bike side can be bought so I'm good there unless that's also available. Thought I'd ask.....want to get that wiring back to OEM. Thanks so much!
An alternative
Buy one of these, remove the pins from the old connector and reinstall in the connector of your choice that uses the same pins. Say goodbye to BMW's proprietary connector plugs at ripoff prices.
The seat connectors are made by Tyco...and on the OP’s bike the previous owner had cut off and discarded both the seat and bike-side connectors to wire another heated seat.
I did some research and pointed him to this:
CNKF 5 Sets AMP/Tyco sensor 2 way male female auto plug waterproof connectors for BWM Porsche benz 968405-1 7-967570-3
by Kaifa elec
Learn more: https://www.amazon.com/dp/B07F8MT6NL/ref=cm_sw_em_r_mt_dp_Y59VFbHZ3SKKJ?_encoding=UTF8&psc=1
5 sets for $21 delivered isn’t bad, and they are also used elsewhere on the bike so you’ll have spares.
