bobcatbiker
A year ago, my ‘04 R1150R (with 38K miles) developed a leak around the oil filler plug. I replaced both the plug and the ring in the cylinder, along with the o-rings. Just this last weekend, it started leaking again. Before replacing them again, I did a search regarding the Hornig filler plug, which seems to be similar in function to the OEM plastic plug. I also found a post about replacing the inner fitting’s o-ring with a harder compound ring from Viton (http://www.ibmwr.org/r-tech/oilheads/orings.shtml). First, have others run into what appears to be a recurring problem and found a solution. Second, does anyone have any experience with either the Hornig plug or the Viton o-rings. Third, and last, has anyone installed the Wunderlich "Dry Safe" oil filler kit?
