gregfeeler
Dances With Sheep
My 1992 K75S with 59,000 miles has developed a hesitation when cold. From a cold start (with or without a couple of minutes warmup) you have to be pretty easy with the throttle or it will hesitate. If you get somewhat aggressive it will bog and stumble. "Cold" in this case is about 65 to 75 degrees. Once warmed up, it runs great. It is also a bit balky to start when cold. It starts best by cranking it a few time, then laying off the starter until the fuel pump cycle ends, then crank it a seconded time with a bit of throttle (all of this is using the "choke" at either half or full position). When warm it starts in standard K-bike fashion. Last tank of gas with mixed town and highway (spirited) riding I got 45.5mpg.
Things I've done or checked:
- air filter clean
- air bleed screw adjustment checked
- valves all in spec
- crankcase vent hose as new
- air leaks around injectors checked with WD40 spray test
- plugs like new and gap correct
- two tanks of non-Ethanol gas run with 1oz./gallon of Techron
- when hot idle CO at 2.5% and at 4,000rpm at 0.5%
- engine temp sensor resistance correct when cold at pin #10 of the FI computer connection (should verify both sensor and wiring)
- TPS position correct
- fuel filter changed 12,000 miles ago, and the bike runs great at speed
- FI computer contacts cleaned with contact cleaner
So, assuming this is a fuel problem, what besides the engine temp sensor controls the cold running mixture? What else should should I check?
- air filter clean
