K75 Fuel Level Sensor and gasket information
J
jcridge
We have a fuel light problem with our 94 K75C, as in it doesn't work normally. If you ground the white wire at the plug and turn the ignition on, the light will work, tried moving the sensor arm up and down with no success. Ohm checked the sensor between the white and brown wires, nothing. Any ideas? Where can I find a level sensor and new gasket?
Thanks,
JC
62161459565 petrol gauge - Up to 01/1993 BUY 1 $105.00
62161459608 gasket ring BUY 1 $5.70
62162305558 petrol gauge - 01/1993 and above NA
Sorry did not see that yo have a 1994 machine...it appears you will need to contact dealer for replacement or beemerboneyard for used parts.
Chicago BMW will give a 20% discount for online orders where you provide the part numbers. Be prepared to wait 2-4 weeks for deleivery.
