rbertalotto
First order of business is a way to mount the GPS. I like my GPS unit "right in my face"....between the handlebars and just above the tank bag, thank you.....
So.....tonight I whipped up this.....
First remove the BMW roundel....
Under the Roundel is a threaded hole.....
Into this hole will go a big ass metric bolt that has been drilled and tapped to accept a 1/4-20 bolt. This bolt will insert through a stainless steel disc I turned on the lathe....
Into the threaded hole goes a "Ram" mount ball.....
And a RAM arm with a Garmin "motorcycle GPS mount" is attached to this ball....
Done!
Next is wiring an aux fuse box and the Amplirider headphone amplifier, GPS and radar detector.....Then fabricate some mounts for my GIVI bags.........
Done!
