I have a Sena SMH-10B which I use with an iPhone 5 and a BMW NAV V. I'm having a pairing problem related to phone calls only. Here's the way things are set up:
- iPhone has Smartphone Link installed and is first paired to the NAV V - no problems and all aspects of the Smartphone Link application work fine.
- NAV V is then paired to the SMH-10B using "phone pairing" - no problem, I get GPS guidance info and my music player works and sounds great.
- On the NAV V's main screen, the phone button is greyed out. The NAV V will not send or receive phone calls even though the A2DP bluetooth audio is connected and working. In the NAV V's bluetooth set-up for the iPhone, "Phone Calls" are checked "enabled" as is the Smartphone Link.
I've tried every which way to connect this, but despite it's relative simplicity, I can't get the phone to make or receive phone calls even though it is paired with the NAV V and should work. I've tried the same set-up with no Smartphone Link involved, same thing. The only possible issue might be that the test is being run off the motorcycle (not in the R1200GSW mount)...in other words I'm powering the GPS via USB from my computer but I do have a bluetooth A2DP link to the Sena as mentioned above. Might this be the problem? My bike is still in covered winter mode in the garage . Perhaps I need to try this on the bike as well? I recall reading something a while back about odd NAV V behaviors if it isn't physically connected to the mount on the motorcycle...
So, thanks for any advice that you might have. Will there be spring this year??
Peter
Peter
